Howdy Richard - I like you encountered a similar problem with my B&D hammer drill. Burnt the drill out, repaired it and burnt it again. I was drilling 3/4" dia. holes 8" deep. These were anchor holes for steel beam uprights. I was disgusted with the B&D performance and bought a Milwaukee (sp?) 1/2" hammer drill. This drill is AWESOME! It is variable speed with 2 ranges coupled with a 2 range hammer (x beats/min) Needless to say I am impressed and have over time, as I can afford them I've been replacing all power tools with Milwaukee brand. Now for the holes - I drilled a 1/4" pilot hole using cheap masonary bits, then graduated to 3/8" Bosch bits. Finally for the big holes I used 1/2" splined Bosch bits chucked in the MLWKE drill. I only lost one bit due to the aggregate. Hit it an nearly lost my wrist due to the "snap" of drill's torque. I just got some cheapo bits and pounded through the tuff stuff and finished off the job with the Bosch bit. It was somewhat tedious but holes were straight and I had a drill that would handle the job. If I ever have the need to drill bigger holes in fixed materials I would rent something. For bigger holes in mobile stuff i.e. plow beams I hope to eventually own a drill press. Hear that family? - Today being Father's Day I could sure use a drill press. Hee-Hee Best of luck and steady as she goes. . . that what has worked for me.
