Sawing sandstone blocks
Arthur Blackwel
06-14-2002 01:33:06
does anyone know the angles for the teeth on a circular saw used for cutting sand stone?
thanks Arthur
SteveB(wi)
06-21-2002 13:50:54
 Re: sawing sandstone blocks in reply to Arthur Blackwell, 06-14-2002 01:33:06
Cut up lots of limestone for veneer with a circle saw and fiber masonry blade. if you don't need perfect ends just score and tap with a hammer and brick chisel
wrenchman
06-15-2002 01:40:22
a friend of mine works part time for a stonecutter & they use diamond grit blades kinda like those used for cutting ceramic tiles.don't think a regular toothed blade would survive long cutting sandstone.kinda like trying to cut a grinder wheel...ABRASIVE!!!
T_Bone
06-14-2002 05:44:39
Hi Arthur,
I've used fiberglass masonary blades that work well on firebrick but very dusty if you don't use some water. I have an old circular saw that I use for cutting things that will screw up a good saw.
T_Bone
Junkman
06-15-2002 15:28:20
 Re: Re: sawing sandstone blocks in reply to T_Bone, 06-14-2002 05:44:39
T-Bone, Spelling lesson for today, MASONRY not MASONARY. Only one "a" in the word. Take it from a bricklayer. Have a nice day.
T_Bone
06-16-2002 00:50:15
 Re: Re: Re: sawing sandstone blocks in reply to Junkman, 06-15-2002 15:28:20
Hi Junkman,
Gees you need to follow me around an correct my spelling errors or get'um to add a spell checker. I'm terrible at spelling.
T_Bone
