Stump Grinder ! ! ! !
Tugboat
06-11-2002 09:12:57
I can't believe the cost to buy or rent a stump grinder. Have any of you fellas built one? I'd like to try to build one but I need an idea to start from!
Any thoughts are appreciated.
Tugboat
DumOleBob
06-14-2002 20:26:53
 Re: Stump Grinder ! ! ! ! in reply to Tugboat, 06-11-2002 09:12:57
I've got a stump grinder for my high flow Bobcat. What a beating those things take! Replacement of cutting teeth, Hyd hoses, etc. is a MAJOR thing. They work very well, but the "consumables" can eat your bank account up!
Richard C. Rose
06-14-2002 03:19:53
Hey Tugboat,
Have you fella's over there forgotten about the good old dynamite.
I've blown out any number of stumps and a good few other unwanted ooglies with mainly gelignite and sometimes nitropril. (I've even blown the back wall out of a bank, legally mind you.)
It's got to be the quickest most cost effective way of moving inert quantities of most things.
Have a go it's fun to, don't forget the camera when you set her off.
Richard.
Don
08-30-2002 12:14:45
 Re: Re: Stump Grinder ! ! ! ! in reply to Richard C. Rose, 06-14-2002 03:19:53
Dynamite huh??? I remember a friend useing it back in the 70's but I don't think the adverage guy can even buy it these days. I own 70 wooded acers in central Missouri that I would like to clear about an acre or two for a homestead and dynamite would do the trick but I don't think it is legal these days.
Geoff Sweeney
06-13-2002 04:49:01
If they have some age on them, when conditions are not dry and windy,I soak them in kerosene and build a mound of coal and /or cut bottom of 55 gallon drum out and use top around the stump to burn them out. Burns down below the surface.
Geoff
Nathan(GA)
06-12-2002 16:18:03
There's a tractor mount one in our market bulletin for $1000, minimum 50hp. A self contained one for $2600.
ACPhil
06-12-2002 08:15:17
Hello, just a different idea on stump removal. If you have a number of stumps, maybe rent a small dozer and push them out. Dig a hole and bury the stumps and then you will have some extra dirt to fill in the holes and anywhere else the area is low. Just a thought, Phil
MarkB
06-11-2002 18:57:11
If you've used a stump grinder, then you know that they are pretty complicated contraptions. I really don't see how you could put one together from scratch and expect it to work as well or as safely as a commercial grinder.
Around here, they rent for about $250 per day. If I grind 25 stumps, then that's $10 a stump.
Al English
06-11-2002 16:50:23
Hi Tugboat,
While I don't know much about them, I do know the newer ones are expensive. But I also know the older machines can be had at reasonable prices. A friend of mine has two old machines. I understand the older ones don't work as well, but if you're not trying to make a living with the unit, the lower cost is probably more important than speed and convenience. Happy shopping...Al English
Tugboat
06-11-2002 17:31:05
 Re: Re: Stump Grinder ! ! ! ! in reply to Al English, 06-11-2002 16:50:23
Al; Thanks for the information. I'll see if I can find an older one. I'm not in the business but I have a small farm with a few stumps here and there. Thanks again! Tugboat
ShepFL
06-12-2002 13:07:03
 Re: Re: Re: Stump Grinder ! ! ! ! in reply to Tugboat, 06-11-2002 17:31:05
Tugboat -
There is a stumpgrinder for sale in the classifieds!!
For my efforts I bought a MF 50c TLB for this kind of work. When done I plan to sell it.
FWIW
Leon
06-11-2002 18:22:28
You can probably buy a servisable back hoe for less money. I had several stumps and blown over trees. Bought a old Ford 550 TLB and dug all my stumps and other odd jobs.
Ready to sell it now and I don't forsee any problems getting my 5K back.
