OT, But need a reverser
Gene Davis
06-04-2002 12:41:50
I know this is not a tool issue, but this is a place to get good advice!! I need a small (lawn mower size 5-8 hp) reversing unit can have reverse and 1 or more forward gears. Here is the hard part, both the input and output shafts need to be on the same plane; preferably horizontal. It needs to have 1/2-3/4 " dia. shafts. and needs to be affordable. Did any mowers use something like this? All I have seen have the input on the bottom or top and the output on the side which gives two different planes. Any body got any ideas? Need your thoughts. Thanks Gene Davis
Gene Davis
06-05-2002 13:50:10
 Re: OT, But need a reverser in reply to Gene Davis, 06-04-2002 12:41:50
Thanks for the help, people. Will use a golf cart reversible engine, variable speed drive set up. Gene
slughammer
06-05-2002 06:18:35
Not sure what your looking to build, but some tillers have forward and reverse and multiple speeds. I have a beast that does fwd and reverse from the engine. The 8HP briggs has 2 counter rotating shafts that spin in opposite directions, belts are hooked to the same driven pully and idlers control the direction. Like I said, it's a beast; I'de look for a tiller with a gearbox. - Slughammer
JoeK
06-04-2002 13:57:22
Most MTDs for last 12yrs or use a variable sheave pulley for a tranny,and a simple fwd/reverse transaxle(top drive).Looking in my OLD peerless book,I found following:
Mod 200 &203,2 spd tranny horizontal in and out
Mod 1200,1400.1700,2000-3spd transaxle with horiz input.
Mod 2300,2400-4spd transaxle w/horiz input.
Would suggest you check old Murray/AMF/Noma units for this type.
