Bobcat
keno henderson
05-29-2002 17:48:17
Sorry for this off topic problem but this tool
side has always came through for me.OK I bought
a 610 bobcat runs great after the normal
plugs, wires, fiters etc.The problem is no high
gear only slow slow low?.Any ideas would be very
helpful.Thanks in advance!.
Keno Henderson [email protected]
Bus Driver
05-30-2002 04:32:04
 Re: bobcat in reply to keno henderson, 05-29-2002 17:48:17
On the left side near the rear of the seat is a handle that moves the sides of variable speed pulley in and out to vary the driven speed. Check with the Bobcat Dealer for the service manual. Buy the manual if still available. Hydraulic pressure must be correct on this pulley. Too little and it will not function correctly. Too much and it will be destroyed.
keno henderson
06-01-2002 15:23:08
 Re: Re: bobcat in reply to Bus Driver, 05-30-2002 04:32:04
Good call on variable speed pulley.Mine is bad.
How does it come off?.Where can I order a manual
online I am 50 miles from a sorry dealer?.610
clark bobcat.My pulley is leaking hydrolic fluid
from the inside onto the drive belt very oiley.
can't see how the pulley comes off engine?. Thanks Hazfun7
