Hard-starting
Roger
05-28-2002 09:49:26
I have a relatively new (last year) lawnmower,
MTD, I think, and it has a priming bulb a the
carb. A nearby sticker states to push the bulb 3
times before pulling the stater rope. Well, it
usually takes about 20 pumps on the bulb before
it'll even begin to act like starting. Anybody
have experience with this? Thanks in advance.
Roger
Neil
06-03-2002 07:54:32
 Re: Hard-starting in reply to Roger, 05-28-2002 09:49:26
If it is BS engine, you might try holding the bulb in longer.
I had my hard starting Craftsman (BS powered, I think MTD built) in to the shop for hard starting from day one.
It said five pushes on the bulb.
The guy told me to count to five while holding each push in. Works every time now.
Seems they don't want you flooding it, so the primer fuel does in real (too) slow.
Kevin
05-28-2002 17:21:53
Remove air cleaner, squirt a small amount of gas into carb inlet, replace air cleaner. If it starts on the first pull, you definitely have a primer bulb problem. My dad quit using his bulb about 4 years ago, he just uses an old oil can with gas in it, one squirt and off he goes!
JoeK
05-28-2002 16:38:02
Primer bulb could be leaking air.It is just pressed in.Take a deepwall socket,which just fits inside the bulbs recess and over the bulb and use it,and a small hammer as a tool(tapping with MODERATE force)to make sure the bulb and its retainer are seated in their hole...Other than that,its a deeper problem within carb.
