Another air compressor question
Joe
05-27-2002 19:46:10
I have a 2 h.p. Ingersoll Rand rated at 7.0 acfm at 40 psig & 6.2 & 90. It has a 20 gal. tank. It shuts off at 100 psi & turns on at 75 psi. 100 psi seems low to me considering I've seen simular units (even little ones) at 125 or better. My nailer works fine at 90 psi or better but by the time the pressure is down to 75 when it turns back on its not sinking the nails. Is there anyway to get it to turn back on sooner? I could adjust the pressure switch up but the manual says not to. Is that safe to do or do I need a different compressor?
Eugene
05-28-2002 08:52:58
 Re: another air compressor question in reply to Joe, 05-27-2002 19:46:10
Send me over the mod.# & ser.# and I will be able to tell you for sure, but I am sure that there won't be any problem turning up the pressure to 125psi, you can also change the differential pressure so it kicks on at 90 psi and shuts off at 125psi....
Rod (NH)
05-28-2002 08:48:37
Hi Joe,
Check your storage tank for an ASME Code label plate...it should be tack welded to the tank somewhere. The plate should have the letters "MAWP" and a pressure indicated on it. MAWP stands for "maximum allowable working pressure". If that is indicated to be 125 psig, then your safety valve HAS to be set at no more than this. You will need a reasonable margin between your normal operating pressure and the MAWP to avoid premature blowing or weeping of the safety valve. A margin of 25 psig is not uncommon for this purpose. My own compressor cuts out at 175 psig and my tank MAWP is 200 psig. I would not consider increasing that cut-out setting on my machine and I don't think you should either...not unless your tank is good for a higher pressure than 125.
You also need a certain differential between the cut-out and cut-in settings on the pressure switch. I don't recall what that typically is but your 25 psig would not be unreasonable. Your manual should indicate that. If that is the case, you are probably limited in getting your cut-in any higher and therefore closer to your cut-out setting without also increasing your cut-out setting...something you probably shouldn't do.
Rod
