Older Quincy Air Compressor Info needed
Zira
05-24-2002 20:30:10
I recently acquired an older Quincy air compressor, the tag reads "A4 7 210058 Size 2 1/2 X 2 1/2." I called my local Quincy dealer, who unfortunately is not very local & mainly deals with commercial accounts. All they were able to tell me was that the pump was obsolete.
What I am trying to find out is:
1. General specifications, including correct rpm range.
2. Parts diagram
3. Availability and price of service parts (gaskets, rings,valves, in that order)
4. Diagram/explanation of the separate unloader assembly that seems unique to Quincy compressors. Parts list also.
5. Some idea of what size motor this unit needs. It had a large, old looking motor that did not work when I got it. I suspect a real 1-1/2 or 2 hp 1725 rpm motor would be okay, but would like confirmation/correction.
Any advice/help is appreciated.
Jim Lafayette
05-25-2002 08:03:36
 Re: Older Quincy Air Compressor Info needed in reply to Zira, 05-24-2002 20:30:10
From Quincy catalog No. 6600-1. The A4 is a single cylinder.
1/2 hp yields 1.56 cfm @ 100 psi @ 400 RPM.
3/4 hp yields 2.46 cfm @ 100 psi @ 630 RPM.
approximate shipping wt is 65 lbs.
Note; compressors are rated at "free air" which means output has been compressed, then let down to atmospheric for volume measurement. You will not get the cfm at the compressed state.
Source
05-25-2002 02:58:34
http://www.quincycompressor.com/
zira
05-25-2002 05:16:36
 Re: Re: Older Quincy Air Compressor Info needed in reply to Source, 05-25-2002 02:58:34
I looked there but did not find anything useful except the name of my local distributer.
Fat Jack
05-25-2002 11:05:15
 Re: Re: Re: Older Quincy Air Compressor Info needed in reply to zira, 05-25-2002 05:16:36
Go back to that site and see if they have a customer service email. I had an identical situation with a curtis compressor. Emailed them and got a response telling what rpm, motor size and rated cfm.
