Hi Dan, I really should have expanded my thoughts a tad more. Pure Argon with Mig works well on light gauge SS SM as it gives lite penetration and reduces weld splatter. As we move to heavier SS metals we can add 1% to 5%, o2 with the Argon that helps with undercutting and adding penetration for Mig welding. Adding more than 5% o2 would cause porosity with-in the weldment. When Helium is added with Argon, 75%Ar/25%He the weld bead is broader and penetration is improved on SS. Then we can add Co2 with Argon for a mix of 75%Ar/25%Co2. The Co2 is primarly added to reduce the cost of pure Argon. We can also use pure Co2 for some SS types but weld splatter is a big problem. Now we get the best of all worlds and end up with a tri-mix of Argon/Helium/Co2. With this mix we get the flatest weld bead profile, good penetration and very little weld splatter on SS. We also can use a heavy consentrate of Helium and add Ar, Co2 or o2 for Mig welding SS. What determines the cover gas, is the composistion of the filler wire and what the filler wire mfg spec's. These cover gasses can also be used for welding other metals. T_Bone
