Montgomery Wards Radial Arm Saw
Chuck, WA
05-16-2002 13:35:10
In the middle of my pole barn project - as you might expect since Murphy is alive and well - my faithful 10" Montgomery Wards Radial saw died. Cost me around $225 if I recall, back in the early 70s and deserves to die peacefully, but $700 for a replacement makes it worth this inquiry.
When I press the trigger, it gives the blade a slight kick with a popping kind of sound. After 10 or 20 of these, it might start and run till I stop it, then repeat.
Any thoughts on the problem, and if it's fixable? I'd almost be sure there's no way to get a replacement motor, and if there was, would probably be pretty expensive compared to the value of a 25 or 30 year old saw, but figured it's worth asking. Besides, never can tell - could be an easy fix.
Thanks!
Here's another possibility.....Al English
05-19-2002 05:26:49
 Re: Montgomery Wards Radial Arm Saw in reply to Chuck, WA, 05-16-2002 13:35:10
Hey Chuck, I just thought of this.
Spemco's primary business is switches. They are very helpful and have managed to find some odd items for me. If it turns out your switch is bad, give them a call, send them the old switch, and hopefully they will come up with a match. The only problem I've had with them is that my small orders and odd requests sometimes have to wait until they're not swamped with more valuable customers. The link below will take you to their website. Good luck...Al English
bob
07-15-2003 09:32:34
 Re: Re: Montgomery Wards Radial Arm Saw in reply to Here's another possibility.....Al English, 05-19-2002 05:26:49
I have this saw as well, model TPC-2610A, but I have a different dilemma: While transporting the saw, it tipped over and the "arm lock" broke in a few pieces (that's the handle on the end of the radial arm that locks at 45 degrees to allow for angle cuts). I've tried to "JB Weld" it but it came apart when I tried to install it (a tricky maneuver). Anyone know where I could get a replacement?
Thanks
Bob
Hank
11-02-2003 18:37:45
 Re: Re: Re: Montgomery Wards Radial Arm Saw in reply to bob, 07-15-2003 09:32:34
I have this saw as well and am trying to get it working. I am having trouble taking it apart to attach the rollers on the left top of the motor housing. It was in pieces and am nearly ready to make it pile sawdust... hopefully
Chuck, WA
05-19-2002 06:11:05
Al...Thanks! That's a great lead. I'll try them. Thanks especially for the link.
Al English
05-16-2002 19:11:21
Hi Chuck,
I have one of those saws and the switch has gone bad twice. Maybe that's your problem too? Good luck...Al English
Chuck, WA
05-17-2002 17:55:58
 Re: Re: Montgomery Wards Radial Arm Saw in reply to Al English, 05-16-2002 19:11:21
Al...thanks! Yup...I think that's it. I tore it down and cleaned it (first time in almost 30 years) but it behaved the same. I'm going to bypass the switch to check it, but I'm almost sure that's it.
Where did you find a replacement - or did it happen while you could still get parts from Wards? I'm expecting to have to jury rig something, though I'm told there's a pretty good place in our town for switches, so might find something that will work. If I have to, I'll leave the switch out and use a "deadman" foot switch.
Thanks again!
Al English
05-17-2002 19:24:13
 Re: Re: Re: Montgomery Wards Radial Arm Saw in reply to Chuck, WA, 05-17-2002 17:55:58
Chuck,
I am still on the last switch I got from Wards. Before I bought that switch I had intended to do as you suggested and use a foot switch. I got a foot switch from Grainger, but it came with a warning not to use it on power equipment!(where else would one use it?) While I think it would have been fine, even superior to the hand switch, I was afraid to use it. I think Grainger was just trying to protect themselves, but if one of my guys was injured using the saw, disregarding the warning would probably put me in a bad spot.
I don't need anything right now, but do you happen to know of anyplace where parts are still available for these saws?...Al English
Jeff, California
01-02-2003 13:43:25
 Re: Re: Re: Re: Montgomery Wards Radial Arm Saw in reply to Al English, 05-17-2002 19:24:13
I have aquired the above mentioned type of saw. What I need is the blade nut. I thought it was 5/8 reverse thread nut.It appears to be a special metric reverse thread nut. Can anybody shed some light on this? Thanks,Jeff
Chuck, WA
05-18-2002 06:14:42
Al...no, I don't know where you could get parts, but wish I did. Relative to the foot switch, I'll try not to go that way, but will if I have to. It's not used in a business, so just my personal safety at stake. Right...where else would you use it. Especially strange since it is intended as a safety device. That's sure a dumb statement, even if it is just for liability purposes. Thanks for your replies.
Neil
05-16-2002 13:57:56
Sounds like the switch on the starting windings on the motor.
Usuaally a small fix by any good motor shop.
Might even be a part you can get through Sears parts if they sold a similar saw.
Sometimes you can get a good bit more life out of it, by opening the motor housing, finding the switch and giving it a good blowing out with air.
Chuck, WA
05-16-2002 17:43:44
 Re: Re: Montgomery Wards Radial Arm Saw in reply to Neil, 05-16-2002 13:57:56
Neil...Thanks! That's the kind of suggestion I was hoping for. I'll definitely check it out. That's my project for tonight - to open it up and see what I can see.
smoknbs
05-18-2002 18:46:44
 Re: Re: Re: Montgomery Wards Radial Arm Saw in reply to Chuck, WA, 05-16-2002 17:43:44
if all else fails go witha single pole spring loaded toggle switch
Chuck, WA
05-19-2002 06:13:48
 Re: Re: Re: Re: Montgomery Wards Radial Arm Saw in reply to smoknbs, 05-18-2002 18:46:44
Smo...thanks! Yup...that's a good solution as long as I can find a way to put it in a place where I can use one hand to pull the saw and one to hold the piece I'm cutting, and still operated the switch.
