Hex bit socket
Dave F.
05-15-2002 10:03:50
Iam in need of an 1/2"hex bit socket 1/2" drive, any body know where I can get one of these the largest I can find is 3/8" at Sears, Thanks Dave F.
bob
05-16-2002 04:28:06
 Re: Hex bit socket in reply to Dave F., 05-15-2002 10:03:50
If you feel you need one for your job. Mc master karr Has them in stock I think. We had them in all our toolboxes at power plant. Yes you can prefab one to do it but if is regular job spend the money and save knuckles
Neil
05-15-2002 14:11:03
Take a 1/2" 6 point socket and a short piece cut off a 1/2" hex wrench.
Put the two together and go at it.
kruse
05-15-2002 13:52:24
Well, Snap-on has one for $20.95:
Snap-On Socket
P.T.Barnum
05-15-2002 14:25:42
 Re: Re: Hex bit socket in reply to kruse, 05-15-2002 13:52:24
"A fool and his money are soon parted"
Al English
05-15-2002 18:36:48
 Re: Re: Re: Hex bit socket in reply to P.T.Barnum, 05-15-2002 14:25:42
Hello Mr. Barnum,
I hope you are kidding. In some cases the older Snap-on tools were better than the current issue equivalents. And, for some jobs I prefer Craftsman, and older SK and Proto tools over Snap-on. But when I need a tool that is thinner, stronger, or stiffer, I use a Snap-on. Are Snap-on tools worth what they cost? That is a determination that each customer makes by voting with his(or her) wallet. Either way, I know lots of really smart people that own Snap-on tools, people that are not, as you suggest, "fools"...Al English
Brian G. NY
05-16-2002 06:03:55
 Re: Re: Re: Re: Hex bit socket in reply to Al English, 05-15-2002 18:36:48
Al, I think "P.T." was probably referring to the difference in cost between Neil's suggestion and the "Snap-On" alternative. As far as I can see, Neil's solution is cheap, yet effective and certainly would suffice for occasional use.
bolt man
05-15-2002 22:56:35
Just get a bolt that has a 1/2" head on it and weld a nut on the end to turn with a wrench. Instead of welding you can also jam two nuts together to turn with a wrench or socket.
