Clausing-Colchester 12 x 42 quick change geared lathe
Jr
05-13-2002 20:19:12
I'm interested in some information on this lathe. Is it a well made lathe? Does it have any bad points and does any one know about what it weighs? I haven't been able to get any information on it. Anything will be appreciated.
Thanks,
Jr
wrenchman
05-14-2002 00:29:14
 Re: Clausing-Colchester 12 x 42 quick change geared lathe in reply to Jr, 05-13-2002 20:19:12
yeah,they are a pretty decent machine & alot better than those cheap imports...main thing you want to look at is condition & whether or not it is banged up...check how much slack is in travels & wear on ways & in head & tailstock...if you can,pull top off gearbox & check gears too.otherwise try each gearrange & listen closely.worn gears will be noisy...not sure bout weight as there were quite a few different models.will be quite heavy though...
JD40C
05-13-2002 21:19:18
Have a look at http://www.lathes.co.uk/colchester/page5.html
Link
