Briggs Stratton overhaul
murray
05-12-2002 20:21:51
Can anyone tell me before I start the job, is it easy to change a crankshaft(bent) for a 3.5HP B&S
90802 engine. ie Nothing to trip me up.
I was planning on removing crankcase bottom, un-doing big end bolts, removing flywheel, removing crankshaft out the bottom and reverse to fit new one. I guess just be careful to keep timing in the right place ie Top dead centre.
Jim K
05-13-2002 16:42:21
 Re: Briggs Stratton overhaul in reply to murray, 05-12-2002 20:21:51
Piece of cake, go for it. a 10yr old could do it easy motor to work on.
Jim K
JiminGA
05-13-2002 07:53:41
Make sure you line the timing marks up correctly for the camshaft. Jim
murray
05-13-2002 17:22:41
 Re: Re: Briggs Stratton overhaul in reply to JiminGA, 05-13-2002 07:53:41
Thanks guys,(Jimin & Rod) And thanks TJ for your email.
I think i have all the info i need now.
Cheers
Murray
murray
05-13-2002 17:21:54
I think i have all the info i ned now.
Cheers
Murray
Rod MI
05-12-2002 20:29:20
Its not that hard I'm only familiar with the 5 hp horizontal shaft engines but there mostly the same you mite wont to have someone put a new bearing on the new crank if you don�t have a press good luck Rod MI
Murray Dunn
05-13-2002 19:35:24
 Re: Re: Briggs Stratton overhaul in reply to Rod MI, 05-12-2002 20:29:20
There is a tool for straightening crankshaft in the engine. I made one several years ago as a copy from a manufactured one
murray
05-13-2002 17:42:11
Thanks Rod
I'll be doing the job soon.
Cheers
Murray
Drill
05-13-2002 20:39:13
 Re: Re: Re: Briggs Stratton overhaul in reply to murray, 05-13-2002 17:42:11
Fairly simple engine, only thing that might trip you up is fly wheel removal if you don't have the right tools. Just be careful you don't bend something. Have fun
