International 806 lift problems
Melvin Shaw
05-10-2002 14:34:47
The 3 point hitch will raise all the way up and lower all the way down. It will not adjust to any height in between. It will work fine if I pull back on the remote lever, but I havr to use two hands to work it.
Ace Schrunk
05-13-2002 11:45:09
 Re: International 806 lift problems in reply to Melvin Shaw, 05-10-2002 14:34:47
I think the load valve must have a bad o ring that is why it is a load valve so if it fails it does not hidh pressure the system like the old 460 560. It is under the set from the front tahes a good size wrench and a good arm there will be a piston in there with a small orifice and an o ring make sure orifice is cleen and good o ring and piston is good shape
