Success welding sa-278 grade c cast iron
chuck williams
05-07-2002 20:33:51
We have a condition where a cavity of erosion in sa-278 cast iron heat exhcanger channel head thats needs to be repaired. The cavity is approx. .70" deep and 2.5" wide and approx. 8" long, cause unknown. This part of the the heat exchanger does not apprear on the "U" Stamped manufacturers Code Data Report. Brackish water is the cooling medium. Any suggesstions??
T_Bone
05-08-2002 06:05:24
 Re: success welding sa-278 grade c cast iron in reply to chuck williams, 05-07-2002 20:33:51
Hi Chuck,
From what little I've read about your problem, sounds like your working with a boiler? In any event I think were beyond the scope of this forum for such a suggested repair as theres alot to consider for the weld repair, ie heat effects of the repair, has x-rays been taken, repair location on the heat exchanger, working pressure, etc.
Without a assured known cause is why I think an x-ray might have to be done as the problem could extend beyond what your seeing.
I would suggest you contact a local HVAC or Boiler contractor to take alook at it.
T_Bone
Steve U.S. Alloys
05-08-2002 05:54:43
You have a gray iron casting of unspecified chemistry Chuck. There are 5 ways to repair this section that come to mind. I can't begin to expound in this context. If you don't get satisfaction in the near future you are welcome to e-mail me. We need to speak by phone so we can both ask questions.
Steve
