Homelite Weedwacker
Steve Ladish
05-07-2002 18:33:15
Lost instruction book...Want to lube the Flex shaft but dont know where the LUBE goes!!!!! !!!!
Ford Man
05-08-2002 19:41:44
 Re: Homelite Weedwacker in reply to Steve Ladish, 05-07-2002 18:33:15
You will have to remove the shaft tube from the motor . Should be fairly self evident how to do it . The flex shaft has squares on each end that fit in sockets on the motor and cutter head .
If you have trouble , post again and I will try and help you .
Good Luck ! Ford Man
