Sleeve puller
ross
05-06-2002 05:32:35
I'm looking for a piston sleeve puller or any info on how i can remove the sleeves from a 188d engine. thank you.
G Taylor
05-07-2002 13:53:30
 Re: sleeve puller in reply to ross, 05-06-2002 05:32:35
Pack the bore with slush made from dry ice and a some methyl alcohol. Wear gloves & eye protection , the mix is about -140F. It will shrink the block & sleeves and they may fall out or at least be loosened. Careful tapping because the cast iron will be very brittle & shatter easily. Or the sleeves can be cut out in a machine shop. The block will need hot tanking,machining & crack checking anyways.
