Gear Repair
Dave
05-04-2002 15:42:46
does anyone know of anywhere that repairs Gears I have 2 bevel gears from a differentional that need repaired?? they would need teeth built up and cut again,, they are 7 inch gears and both are welded onto shafts Thanks Dave
I am near Pittsburgh Pa.
Chris C.
05-07-2002 15:03:15
 Re: Gear Repair in reply to Dave, 05-04-2002 15:42:46
Try Boston Gear (on the net but not sure if it's BostonGear.com)
kraig WY
05-05-2002 13:34:53
Any one with a good milling machine and dividing head (indexer) should be able to make the gears. I don't have a dividing head but I have a lathe milling attachment that is marked off in 1/4 degrees for the full 360, and set it up on the milling machine. I've made gears, granted, not the quality of a good machinest but they've worked. To heat treat them, heat them until they reach critial temp. (where a maginet will no longer attract the metal). Oil quench. I try to estimate as close to the proper temper I can and use a lead pot (for casting bullets) and a lead themonter. Not very sicenctific or professional but it always worked for me. Saved money and had fun.
Al English
05-05-2002 05:09:14
Hi Dave,
To repair the gears in the manner you described they would need to be annealed(un-heat treated), welded, re-heat treated, tempered, then re-ground. And when the process was complete you would have a gear that wasn't as good as new. But anything less than this is a guarantee the gears will break right next to where they were welded.
If they are available, either good used parts, or replacements from the manufacturer, are your cheapest alternatives. The third choice is to have new ones made. The general availability of modern gear cutting/grinding equipment now makes this a possible/practical option. Although the process is not cheap, neither is it unaffordable. I have had splines, gears, and sprockets made for various projects. Any large industrial city will likely have at least one shop offering these services. If you decide to go this route the shop will need either some precision measurements from your piece of equipment, or the disassembled gear housing unit. Good luck...Al English
