Motor capacitors
Farmer-Gene-WI
05-02-2002 07:29:05
I have a 5 hp elect motor, 220 volt that I had been saving as a spare in case one of my others quit, well now I need it but somebody borrowed the capactors out of it. Theres no markings any where to even tell what brand of motor it is. How can I tell what size mf capacitors it takes? Thanks in advance
Steve
05-03-2002 07:23:09
 Re: motor capacitors in reply to Farmer-Gene-WI, 05-02-2002 07:29:05
I just repaired a 5 hp Dayton and it had two start caps at 1068 mfd and 230 volts each.
G Taylor
05-02-2002 12:22:48
The dry starting capacitor(s) or a wet running capacitor?
Farmer-Gene-WI
05-02-2002 13:16:30
 Re: Re: motor capacitors in reply to G Taylor , 05-02-2002 12:22:48
Starter ones, it takes two, the run one is still there.
G Taylor
05-03-2002 09:13:05
 Re: Re: Re: motor capacitors in reply to Farmer-Gene-WI, 05-02-2002 13:16:30
Steve's number are in low end of the correct mcfd range. A size larger will improve starting torque. Doubling or tripling the size of the run capacitor will reduce running current & voltage drop on long wire runs. Overload size will have to be reduced to maintain protection.
RayP(MI)
05-02-2002 08:47:33
Check with any reputable motor rewind shop.. They'll know. Are the specification plate(s) still on the motor? They may tell.
