Log Splitter
Gary Zak
04-30-2002 18:22:43
I just finished a log splitter and started it for the first time . Works very well , but the hydraulic fluid turned white and fomed out the filler cap . I stoped the machine , I may have over filled the oil tank ?? Any idea's . thanks Zak
Jake
05-03-2002 21:00:06
 Re: Log Splitter in reply to Gary Zak , 04-30-2002 18:22:43
Does your oil return line go all the way to the bottom of the tank? It needs to return below oil level to reduce foaming.Jake
Joe (Wa)
05-01-2002 22:53:49
Hi Gary, I agree with T_Bone probably just air entrainment from filling an empty system. I would let it set overnight and recheck level, loosen drain plug and check for water. If no drain plug and you suspect water, check with thieving paste. May take several runs and rest periods to get the air out. Regards, Joe
T_Bone
05-01-2002 14:59:16
Hi Gary,
Probably just air. You need to cycle it a few times with less oil in the tank then fill when all is working ok. Remember you need room for the oil to expand upon return.
If it was water contamiated, it would be milky brown color.
T_Bone
JD 4000
05-01-2002 13:29:18
if you see white. you may had water in there some where, best to change it and filter.
shawn
05-01-2002 10:56:32
what oil did you use? You may know but if you don't detergent oil foams if i am not mistaken.
Gary Zak
05-02-2002 18:04:27
 Re: Re: Log Splitter in reply to shawn, 05-01-2002 10:56:32
Thanks for all your help . I used #32 hydraulic oil and after I let set over night it went back to normal colour . I ran my log spliter for 1/2 hour with less oil 3/4 full and it didnt over flow
but I did notice a white foaming at the top off my oil tank . I have not put this
machine to the test yet but I thought I would find out if this was normal before I ran it to long . I don't know or understand
what detergent oil is .
thanks again
Dusty
05-02-2002 18:17:03
 Re: Re: Re: Log Splitter in reply to Gary Zak, 05-02-2002 18:04:27
Most motor oils are detergent to clean the engine while lubricating.
