REPAIR U JOINT
HANK
04-30-2002 12:32:16
I NEED TO REPLACE THE END OF MY BRUCH HOG SHAFT.
PLEASE TELL ME WHAT THE TRICK IS.
I REMOVED THE KEEPER KEYS; THATS AS FAR AS I GOT.
THERE IS NO FREE-PLAY. LOOKED LIKE SPECIAL TOOLS
OR SPECIAL KNOWLEDGE REQUIRED.
thurlow
04-30-2002 16:55:02
 Re: REPAIR U JOINT in reply to HANK, 04-30-2002 12:32:16
I've always used a vise, nuts of a size that will just go into joint and old bearing "race" on other side. Push cross out enough that you can get 'ahold' of bearing and remove.
Tom
04-30-2002 18:49:56
 Re: Re: REPAIR U JOINT in reply to thurlow, 04-30-2002 16:55:02
Or you can use sockets, one smaller than the bearing to push it, one larger than the bearing to push the other bearing into, using a vise.
