Air compressure
TOM
04-24-2002 08:31:27
my air compressor builds up to about 30 lbs and then starts slowing down and by 40 lbs it has stopped the motor completely. I have had the motor rebuilt. It is a Sanborn 5 hp 60gal. single stage. any ideas???
G Taylor
04-25-2002 06:50:15
 Re: air compressure in reply to TOM, 04-24-2002 08:31:27
What voltage is at the motor starter without the compressor running, at 5 psi & when the stall occurs. If voltage isn't within 10% of the motor nameplate, she won't work worth diddly.
veena
10-09-2003 04:14:25
 Re: Re: air compressure in reply to G Taylor , 04-25-2002 06:50:15
send a model of air compressure to my mail addresss.
JoeK
04-24-2002 12:19:18
Could be a stuck check valve,causing the pump to have to fight full tank pressure all the time.
Jeremy
04-24-2002 11:00:45
Let the compressor come up to the point where it slows the motor down and stalls it. Then pull the belt off quickly and try spinning the compressor pulley by hand. See if the compressor feels rough or really tight. We lost one of the Sanborn compressors on the farm when the connecting rod seized on the crank...with a full crankcase of oil.
Neil
04-24-2002 10:38:23
When did this start?
All of a sudden, or over time, or never worked right?
