Anyone know of a 3-pt post pounder I can put on an N with 23hp?
Rob
04-20-2002 04:22:26
I suppose I can pull a trailor. I'd like to hear from anyone having experience with building a lot of fence. I'm considering 1,600+ posts to start with and I don't wanna lift a 25-55# post pounder that many times.
A front loader sounds like an option but it maybe awkward for use on jobs were a guy will put in at least 80 posts on any given day.
Dave_Id
04-25-2002 17:34:12
 Re: Anyone know of a 3-pt post pounder I can put on an N with 23hp? in reply to Rob, 04-20-2002 04:22:26
I have a 3pt pounder that runs of the pto. It pounds pointed posts in very well, and of course steel posts. It takes very little hp. and does a fine job. I may be interested in selling it. Email me if you are interested.
cd
04-22-2002 20:30:50
I read these posts and saw a few people suggesting using loader, I have a friend who just lost half of his thumb the other week, they were putting in posts and his dad was hitting them in with a payloader and he turned to go to the next post and put his hand on the previous post out of reflex and about that time he got whacked, he said they had some miscommunication, he is in his teens and will have to live with this forever so I urge people not to use loaders in this way.
Big Jake
04-22-2002 08:07:34
Rob: First off I assuming your wanting to drive in T-post. I use a pneumatic driver ran off a portable air compressor. We have shale rock about a foot under our soil & this will drive them thru
it. It will also penetrate the t-post thru tree roots
Link
For rolling up old wire I use a gasoline powered
roller made by E-Z products in Texas. The winder cost over $800.00 bucks but it will roll up a 1/2 mile of wire in less than 5 minutes & leave you with a manegable roll of wire.
DumOleBob
04-22-2002 07:48:24
Whoops, I got so up on telling you about the Postmaster used on skidsteers that I 4got about SHAVER POST POUNDERS. I had one & it was great!However, there is no way that type of pounder can even come close to the Postmaster when it comes to one guy putting in LOTS of posts!
I can't find Shaver's web page, but they are very good 3 point drivers. Most any farm supply outfits sells Shavers. Like most of 'em Shavers use gravity - AND two large springs - to drive the post. Believe me, you do want to keep your hands out of the way!
The Postmaster strikes about 50 blows a minute & you can load the "hammer" with hundreds of pounds of extra weight - like washers, chains, etc! Man does it ever put 'em in the ground!
There are any number of the Shaver type of pounder on the market, but I believe they are a "leader" of sorts. However, they are generally a two man operation.
I live in the Rocky Mts. & here the deal is to get the post in & then use the weight of the tractor to push it straight. If you fool around with trying to drive it 100% straight from the get go you'll be all day.
Mike C.
04-23-2002 08:39:27
 Re: Re: Anyone know of a 3-pt post pounder I can put on an N with 23hp? in reply to DumOleBob, 04-22-2002 07:48:24
Here is the link for the Shaver post pounder.
http://www.rowterra.bc.ca/ASSORTEDpg.html
Matt
04-21-2002 19:29:25
We have a Danhuser PTO model. It works good. I think they also make a trailer model. If you are driving T-post and working by yourself, using a tractor type driver is very slow; much faster to drive by hand. I would look into the air powered T-post drivers. I was impressed at what they would do, and they are a one man operation. You can buy a driver and an engine driven compressor for less than what you could buy the tractor mounted driver for. The disadvantage is that you can't drive your corner posts with it.
Good luck,
Matt
Dell (WA)
04-21-2002 13:46:15
Rob..... ....I know of at least 5 different 3-point post pounders. Farnham, Schavetz, Furst, Kingcutter, Dansuer. (all in the $2000 price range) They all require remote hydraulics which as you know, your N-Tractor does not have. However, if you know how, there are several external hydraulic work-arounds.
Remember, most frontend loaders are power up and gravity down, not the best for pounding a fence post. But I suppose if you put about 250# of deadweight in the bucket, it'd come down pretty fast, assuming you can lift your bucket high enough to begin with.
BIG SECRET for pounding pointed pressure treated wooden fence posts: PILOT HOLE. Jab a 6' 15# pointed end crowbar into the ground and grind it around in a circle. Do this until you can get the bar 16-24" deep. Then plant your post, then pound your post as deep as you want.
Remember, driven fence posts are stouter than any backfilled posthole. And don't plant your post in cement because it will rot the wood..... .....Dell
Rob
04-21-2002 14:12:59
 Re: Re: Anyone know of a 3-pt post pounder I can put on an N with 23hp? in reply to Dell (WA), 04-21-2002 13:46:15
Thanks Dell. Danuser makes a pto post pounder that should work real well on the N. They made the Dearborne/Danuser pounder I guess. The bucket isn't what I had in mind. 1600 posts to start so I'm gonna get it right and skip the jake-leg stuff.
Seems those hydraulic kits all take too much hp. You brought up a couple of new names so I'll check them. That pto unit looks good though, simple and easy to install and maintain. Probably less $ too.
I've seen pounders that can operate from 1000psi to 1500 psi but at 4gpm. If I see one that would work at a 2.5gpm I might go for it.
I'll have to remove the old fence and I'm wondering if I should just tie it on the drawbar and rip it out or take a more "professional" tack. Any thoughts on that?
DumOleBob
04-21-2002 08:04:04
If you really want to put a lot of posts in by yourself check out POSTMASTER, Strathmore, Alberta, Canada (toll free 1-888-317-5878, Reg tel = 403 934 5878). Dealers in the USA.
Works on most skid steer loaders so Bobcat, Case, Deere, New Holland dealers, etc should know about it.
I've used on and the darn things work. They claim 60 posts an hour which is a bit much, but it will flat out pick 'em up, align 'em & get 'em in the gound - F A S T! When I was in to it four years ago they cost $6,000 - but well worth it.
Rob
04-21-2002 14:14:56
 Re: Re: Anyone know of a 3-pt post pounder I can put on an N with 23hp? in reply to DumOleBob, 04-21-2002 08:04:04
Hey Bob, Were you in the business? Email me let's talk. Thanks.
Rob
04-21-2002 14:01:11
Don't think I can use it but I sent away for info, thanks. Lotta money!
