Ajax air compressor. Know anything about it?
Jeremy
04-17-2002 19:56:35
The home we are buying has a shop off to the side. It comes with an air compressor. I'm trying to find out more about it.
Ajax Corp
Model SRW5-30 s/n 8825
Motor:
Gould Century motor
Model 8-150257-02
Frame: Y56
Type: DP
HP: 5.spl (<--This is what I don't understand)
3450RPM
230VAC, 1ph, 15amps
Service factor: 1.00
s/n BA8
What in the world does 5.spl mean?
Trader
04-18-2002 08:34:25
 Re: Ajax air compressor. Know anything about it? in reply to Jeremy, 04-17-2002 19:56:35
Hi Jeremy, Cant help ya with the cfm and that but maybe they have a website you could look up or write to the company. I found out about a compressor that way. I was surprised they responded to my request of a really old compressor that I didnt even buy new myself. Anyhoo.. That 5 hp special means they used funny math and rated it at what it could develop at peak. Also notice the 15 amp rating. That is also a givaway that it is phony numbers.A real 5 horse would be in the mid twenties on the amp rating. It may be all you need though and work out fine for you.
PCC-AL
04-18-2002 07:09:43
Hi Jeremy, You may want to check out my post below "Defects and Recalls". Ajax is one of the name brands listed there. Good luck.
Bonar Hasiholan
12-28-2002 11:25:27
 Re: Re: Ajax air compressor. Know anything about it? in reply to PCC-AL, 04-18-2002 07:09:43
We are the supplier Gas Transportation for Pertamina DOH Prabumulih
South Sumatera-Indonesia
i need your help to find part, we have 2 engine compressor:
1. Ingersoll Rand IR.6.12.SVS.3.S/N 139-H
2. Ajax DPC 600 S/N 80809
please i need your confirm asap, or you can give distributor store or person who can help me find the part in Indonesia with your recommendation of course.
give your email back!
Bonar Hasiholan
12-28-2002 11:24:37
i need your help to find part, we have 2 engine compressor :
Jeremy
04-17-2002 19:58:37
I should add that I'm curious as to what sort of cfm this unit puts out. It's single stage, appears to have two pistons, and is rated at 150psi (although I don't know what the pressure switch is set at as I haven't fired it up yet).
