Truck Tires
Bob
03-24-2000 18:02:22
I bought an old International Loadstar farm truck. It has 8-1/4 X 20 tires mounted on split rims. I am having trouble finding used tires in this size range. Can I mount 9 X 20 tires on these rims? Also, is it legal to run recaps on the front tires?
indian
03-02-2003 15:16:03
 Re: Truck Tires in reply to Bob, 03-24-2000 18:02:22
Im a off road lover if there is about waist high mud Im bound to be there so were can I find 4 15 inch tires for my 83' ranger?
Carl
03-27-2000 13:30:55
Recaps are not legal on steer axles. No matter what size tires you go to have a truck tire shop mount and inflate as they have a cage.So nobody gets hurt if the lock ring blows off.
D C Dale
03-25-2000 19:40:45
Generally you would be ok going to te 900 - 20 . on that size wheel. and we know tubeless truck tires are in 1/2 inch increments, ie: 11X22.5 , 8.75X16.5 etc Caps on the front generally are frowned on , Check with local DMV
jim
03-25-2000 00:00:16
There is a rim size stamped on outer, inner surface. You most likely have largest tire for that rim. If thats the case, you can also use 7.50-20. If I recall 9.00-20 are tubeless.
