Gen set
max
04-13-2002 07:23:42
My Honda 3000 watt was running a 1/2 hp pump and the pump motor started smoking and clicking after a minute. I plugged it into a wall plug and it was fine. I turned the voltage of the gen from 118.9 to 120.5, and the pump ran fine.
Is there a problem with the motor, or is this ok? Also, I know (watts=volts X amps) so why do some gen sets say kva and others kw?
Mike W
04-13-2002 20:19:23
 Re: gen set in reply to max, 04-13-2002 07:23:42
Hi Max, Does your genset bog down when the motor starts? The slight change in voltage setting shouldn't make that much difference. I would check the pump for a winding that looks burnt.
Kva times the power factor equals true power. Loads like a motor cause the current to lag the voltage. In this case, multipling voltage times amps gives a too high answer. I measured the PF on a appliance, and it was about .85. I think sone generators are rated in kva to allow for inductive loads.
