Another Welder question
Tyler(WA)
04-12-2002 07:39:27
I do know what I'm doing with both electronics and high current situations so please avoid commenting on safety concerns here.
I have a 240 amp welder and can add a full bridge rectifier to make it an AC/DC welder for about $50 worth of components. Why wouldn't I want to do this and why don't more people make this rather simple modification to their older AC buzz boxes?
Mike D
04-13-2002 13:53:34
 Re: Another Welder question in reply to Tyler(WA), 04-12-2002 07:39:27
I took apart a miller ac dc welder. In addition to the bridge, there was a single wind coil,and a small cap at each diode. I recanize this to be a filter to take out ringing and stablise the output.There is also a 3900ohm resistor across the final out put. Years ago I built a bridge out of some old alternater parts. All was fine, untill I turned on the high freq. unit. The spurious high voltage promptly pierced the diodes. I think the resistor would have prevented this. Good Luck and keep us informed, Mike
chris
04-15-2002 17:40:18
 Re: Re: Another Welder question in reply to Mike D, 04-13-2002 13:53:34
My grandpa built one ,the only problem was it sunburned the heck out of exposed skin even through t shirts. I have a factory built dc now it doesnt seem to sunburn like gramps machine did . we also blew out the diodes when hooked it to the "freak" box for the tig
Tyler(WA)
04-13-2002 17:44:15
Thanks Mike - That's got to be a low pass filter. The resistor is part of it and shorts the high frequency to ground. The coil, capacitor and resistor all work together.
Thanks for the observation. High frequency can really take out a silicon junction (like a diode.)
Rory
04-12-2002 09:20:08
I built my own rectifier and have used it on my Lincoln buzz box for years. I used 4 300 amp diodes to build the rectifier. I purchased the diodes from Surplus Center for around $10.00 each. There current catalog lists 2 300 amp diodes:
The first one is a 300a 200v removed from service 3"pigtail Item number 22-1151 $11.99.
The other is a 300a 600v removed from service Item number 22-1124 $12.99
Their number is 800-488-3407 I strongly suggest ordering a catalog as well.
I have not noticed a reduction in current I am sure there is some but not significant. I have mine built so i can convert it from ac to dc+ or dc- by unplugging and moving the cables.
llamas
04-12-2002 08:59:26
Sure, you can do that. Them's some hefty diodes, you'll need a large heatsink and a fan might be good too. One reason this is not done more often is that diodes this big have generally not been priced low enough to make this a practical proposition until quite recently.
But the main reason this is not done more often is just exactly what is described below - your 240 amp AC welder becomes a 120 amp DC welder, and that's a little on the small side for a stick welder. Now, I have seen this done several times, very successfully, to make a lower-power scratch-start TIG welder. And no doubt there are other similar applications.
llater,
llamas
Tyler(WA) Even with a full wave bridge?
04-12-2002 09:25:24
 Re: Re: Another Welder question in reply to llamas, 04-12-2002 08:59:26
The drop in price of the diodes is what makes this an option today but I don't see the loss in amps if you build a bridge rectifier as opposed to just slapping in a single big diode.
A single diode creates a half-wave rectifier and virtually cuts 1/2 of the current wave from the output. A full wave rectifier (bridge rectifier) routes both waves to the output and creates 1.44 times the input AC voltage.
Heat sinks are a must and a fan is strongly advised but I think I should get good results from this solution. Perhaps the only way to tell is to give it a whirl and see how it comes out.
$50 worth of diodes isn't too much for an experiment.
llamas
04-15-2002 07:34:53
 Re: Re: Re: Another Welder question in reply to Tyler(WA) Even with a full wave bridge?, 04-12-2002 09:25:24
Your observations are correct but, I think, not applicable.
AC current is measured RMS, DC current is not. And you're talking about voltage, not current. Incidentally, I believe your factor is backwards - for a true sinusoidal AC, a full-wave rectifier can produce a DC voltage output of 1/1.44 = 0.7 times the peak AC voltage.
The rectifier on its own will not do that, of course, - all it outputs is full-wave rectification, or a series of wave segments all at the same polarity relative to ground. To get close enough to a "true" DC, additional smoothing is required - eg large capacitors.
I think you'll find that the DC current output of an AC welder rectified as you describe will come out roughly as I described - about 50-60% of the corresponding AC output current. That's the result for the various transformer-rectifier welders on the market - eg the Lincoln AC-DC 225/120, which has a full-wave rectifier for the DC side.
llater,
llamas
Al English
04-12-2002 11:42:41
Hi Tyler,
You would think a diode bridge would cause no significant loss. But for reasons I don't understand, that's what happpens. Welders that are built this way from the manufacturer have less output on DC than on AC. If anyone knows why that is, I'd be interested in knowing...Al English
Tyler(WA)
04-12-2002 12:19:52
 Re: Re: Re: Re: Another Welder question in reply to Al English, 04-12-2002 11:42:41
I don't know how they build the bridges for welders but hearing that they drop the current in 1/2 made me think they were only half wave rectifiers.
If the current drops like that with a full wave bridge desige, I'd have to blame it on the .7v drop accross each diode. That would be 1.4v for a full wave bridge (only two work at a time). If working voltage goes really low during welding (think it does) then dropping 1.5 volts could explain the big drop in current.
Just a hunch.
Al English
04-12-2002 13:00:05
 Re: Re: Re: Re: Re: Another Welder question in reply to Tyler(WA), 04-12-2002 12:19:52
Tyler, That makes sense. The current drops I've noticed are roughly 20%, not half. The voltage across the arc of a small transformer welder(buzz box) is about 12 volts. A 20% voltage drop at 12 volts is 2.4 volts, close to the 1.7 you mentioned. Thanks to you I know a little more than I did when I got up this morning...Al English
