Hi Don, There were excellant replys to your post. My head is fairly clear tonight so let me give a reply. Yes I was referring to base metal penetration on my last post. As stated, joint design has everything to do with penetration. As a general rule anything over 1/4" base metal thickness needs a bevel of approx. 45 degrees. Thats 22.5 degrees bevel on each piece on a groove weld joint. Root face should be limited to 1/8" maxmium with a 1/8" maxmium root opening. Some joint designs require less bevel and some joints require more. This would also be effected by the welding process selected. Now that I gave a general rule of thumb, let me blow that therory out of the water with this example. We have a 1/4" square butt joint weld with 100% joint penetration required with the back of the joint not accessible. As stated above we don't need a bevel, and root opening will be 1/8" and we will use a 1/8" 6010 electrode a very deep penetrating electrode. Using 1/8" 6010 DCEP there would be no way we would achieve 100% penetration without a bevel on this joint design with out back gouging the weld which we can not do because it's not accessible. We could however achieve 100% penetration with a 30 degree beveled joint design or by using a backing plate with a 1/4" root opening. As a welder gains experience, it will be apparent when more or less bevel is needed for a pictular joint design for 100% penetration weld no matter what the joint design is. Is a 100% penetration weld needed all the time? Nope, as a fillet joint weld would be good example. The AWS code book has several pages of joint design spec's so it's not possible to cover all of them in this post. T_Bone
