D6 drive sprocket
Frank
04-07-2002 20:19:31
I have a d6 8u caterpillar that has a crack in the drive sprocket. What ac weld rod can I wse to weld it. the book only says "high tensile rod".
T_Bone
04-08-2002 23:17:07
 Re: d6 drive sprocket in reply to Frank, 04-07-2002 20:19:31
Hi Frank,
You can get 10018 in Lincoln thats rated for AC use. I've never used any AC low-hi rod in the past 10yrs so it may weld ok. I would tend to use a hotter arc than I normally would and I weld very hot to begin with. You can buy 5lb packages and try it so you don't have alot of money into the rod if it doesn't work out.
T_Bone
