Chainsaw
Wes
04-07-2002 13:41:48
I have a poulan chain saw and only used it one
time it sat for about 6mos and did not use.Now
the thing will not crank.I took it apart and found
permatex in motor.Why is that?Should i buy rebuild
kit or should I get a gasket where the company put in the permatex?Or shuold i just re permatex
and get new gaskets?
Russ
04-07-2002 17:24:52
 Re: chainsaw in reply to Wes, 04-07-2002 13:41:48
Hi Wes, you want to use an RTV type sealant. This is what many manufacturers including Electrolux(Husky, Jonsered, Poulan, etc...) and Stihl use in some of their models in lieu of gaskets. Done carefully so as not to get any inside the crankcase that will float into a bearing, it works well. Russ
