Chainsaw
frankie
04-07-2002 10:04:29
Cutting brush in grassy areas,cant keep chain on bar,tried 2 different makes(new) still the same problem,anyone have an answer or a Make of a saw, Sears saws wont cut it,,
Redtractorman
04-07-2002 10:58:38
 Re: chainsaw in reply to frankie, 04-07-2002 10:04:29
I agree with everything that bbott said but would add that you may be running chain to loose these new small saws run very fast and need chain tight,if you have a worn blade on your chain saw it will let the chain jump off also.
bbott
04-07-2002 10:47:49
I don't think there's anything wrong with your saw, it's just trying to tell you something.
Chainsaws don't make good mowers.
Cutting brush in the midst of tall grass and assorted crap with a standard bar is a very dangerous thing. For that matter, cutting brush with a standard bar without other junk in the way is dangerous. Like you've already discovered, it will tend to throw the chain, kick back and jam up at the slightest provocation!
They do make a special 'bow bar' that is designed for cutting brush (but still not grass). Beyond getting one of those, you might try to clear the grass away with a brushcutter as best you can before you try to use the saw.
If you don't have them already, I'd suggest getting some saw chaps. They just might save your leg or your life.
-- bbott
