SDS/SDS plus hammer drill bits
Dave F.
04-05-2002 21:54:57
I have an old Hilti hammer drill that uses SDS bits are the SDS plus bits the same will they interchange, the SDS maxi. bits look different & I don't think they will work any advice will be greatly appreciated thanks Dave F.
Ben
04-06-2002 10:47:36
 Re: SDS/SDS plus hammer drill bits in reply to Dave F., 04-05-2002 21:54:57
Dave: The hilti gun uses SDS-MAX bits, which is a larger bit system than a SDS-plus. SDS plus only goes up to size 1-1/8, while you can get a max bit up to 2", check the drilling capacity of you gun and drill accordling to size of your hammer.
Good luck
