Damaged welder?
Ezmoney
04-05-2002 15:50:58
I have an Lincoln SP 130T 230v (single phase) mig welder wich was working fine until I plugged it into 440v three phase plug and the smoke started rolling out. I know a little about electricity and was wanting to know where to start looking for troubleshooting (or a new welder?). Any help will be greatly appreciated. Thanks!
frankie
04-07-2002 14:12:21
 Re: Damaged welder? in reply to Ezmoney, 04-05-2002 15:50:58
do what you should have done first----get someone who KNOWS electricity
Ezmoney
04-06-2002 11:52:11
third party image
Drawing for welder
Safety First Guy
04-06-2002 06:52:57
I'm not promoting link site, but the chart should be useful.
Link
Mike W
04-05-2002 20:06:07
Don't plug it in yet; you need to find the part(s) that let the smoke out. I looked at the drawing of my Hobert to see what might happen if I put 440v in it. If I didn't squeze the trigger, only a small fuse should blow.
You need a drawing of the circuits. I would do a visual check for burned components. If you can see the windings on the main transformer, are they shiny or dark(burnt).
I need a drawing to go much farther; but it shouldn't be too dificult to trouble shoot. May just be a minor part that went. A small resistor can let out a lot of smoke.
Ezmoney
04-06-2002 11:40:49
 Re: Re: Damaged welder? in reply to Mike W, 04-05-2002 20:06:07
third party image
First of all thanks for the info! I have found a circut drawing of the welder, unfortunatley it (welder) is at work now. I posted the circut drawing in a link for veiwing and info (below).
Link
Jim K
04-05-2002 16:57:20
You can try pluging it back into 230v power and try to weld with it, it may work, but I think that you might as well start looking for a new unit. Good luck Jim K
