Stihl Weedwacker
Warren
04-03-2002 12:42:13
Just picked up a nice, used, Stihl straight shaft weedwacker at an auction - so no manual.
Does anyone know what the gas:oil mixture should be.
Does anyone know if there is any lubrication of the shaft required or is it lifetime lubricated?
Thanks.
Warren
John - NY
04-04-2002 07:21:20
 Re: Stihl Weedwacker in reply to Warren, 04-03-2002 12:42:13
Warren,
It appears that you can secure a manual on the trimmer through Stihl's website at www.stihl.com under library/literature. I downloaded parts listings for my Echo off the web. It's really great that the companies are making their information accessible! Good Luck! John
bob
04-03-2002 21:10:46
older stihls - FS-60 & FS 80 took 25:1 (one pint oil to l 1/2 gallons of gas), then FS-81 when to 40:1, then finally 50:1 in latest models
Don
04-03-2002 18:23:58
What model # is it? all the stihl's I know of run 50:1
Mac
04-03-2002 17:03:21
Mix of 40:1 is OK, had a stihl for 12 years and greased it once, didnt need it then. Grease can be obtained from stihl or about any mower shop.
DAVE S
04-03-2002 16:17:10
I use 50:1 in all my stihls
John in MA
04-03-2002 16:16:10
Stihls of the past ran 40:1, newer ones run 50:1. I'd use 40:1 on all of them.
Jeff Pack
04-03-2002 15:24:42
25:1 is a pretty safe mixture for most any
2 stroke, using good 2 stroke oil.
george
04-03-2002 14:14:12
The shaft requires grease at the head. STIHL sells this in a tube.
Warren
04-04-2002 13:35:41
 Re: Re: Stihl Weedwacker in reply to george, 04-03-2002 14:14:12
George,
Thanks for the comments. I assume that the head you refer to is the trimming end and not the power end. How is the head greased? There is no visible zerk and doesn't seem to want to be opened very easily.
Warren
george
04-05-2002 12:37:36
 Re: Re: Re: Stihl Weedwacker in reply to Warren, 04-04-2002 13:35:41
Warren:
If I remember correctly, the trimmer end has a hex nut which when removed, will allow for grease to be squirted-in from the plastic tube.
Warren
04-08-2002 07:00:33
 Re: Re: Re: Re: Stihl Weedwacker in reply to george, 04-05-2002 12:37:36
George,
Thank you very much for the info.
Warren
