Welding helmets
don s
04-02-2002 23:01:09
I am looking for a solution to the glass lens fogging up when welding thanks don
Trucker
04-03-2002 20:56:59
 Re: welding helmets in reply to don s, 04-02-2002 23:01:09
Wash it with dishwashing soap,dry it off,if that dont work switch to plastic untill the weather gets better.
Pete in Ks
04-03-2002 09:14:30
I have an Anti-fog cloth that I got from "Stanley" years ago. I wipe the lens with it and no fog. It is years old and still works.
Mark Kw
04-03-2002 04:16:44
Try going with the plastic lenses. They are much better for safety than glass anyway.
You'll still get some fogging when they are cold but it's not as bad as with glass, need a higher temp difference with the plastic before you'll have problems.
One thing I did find that also helps is treating only the outside of the clear cover plate with rainX. It helps keep the smoke and dirt from sticking. Also, if you wash the filter plate and inside cover plate in warm water with a little bit of Ivory brand dish detergent, it'll help keep the static off them which also helps keep 'em clean.
