Portable welder make ok emergency generator?
IaGuy
03-31-2002 10:26:28
Any downsides to using a portable gas powered welding generator as emergency power source..will need approx. 10KW to run heat pump/coils furnace. I have put in the big switch-over on the meter pole but don't trust the old tractors to standup to a PTO generator. I need a welder anyway. Anyone try this?
bbott
03-31-2002 11:57:16
 Re: Portable welder make ok emergency generator? in reply to IaGuy, 03-31-2002 10:26:28
A 10 KW load will require a good sized setup. You're looking at about a $4,000 bill. In diesel add another $2,500
Take a look at the following.. Miller Trailblazer 301. It has completely seperate generators for the welding/auxillary outputs.
http://www.millerwelds.com/main/products/enginedriven/M16401/
