Assembly oil
sherburne
03-26-2002 12:37:12
What do you people like for assembling a rebuilt engine for lubrication?
Trucker
04-03-2002 21:59:41
 Re: assembly oil in reply to sherburne, 03-26-2002 12:37:12
On a rebuilt engine unless you put a new cam in it,you use the same oil you are going to run in it.I have rebuilt a lot of engines and thats the way they taught me to do it.In the case of a new cam you need to use the lube they supply with the cam on it.Just use a lot of oil and if you can prelube it by turning the oilpump with an electric drill before you fire it up the first time.Thats the best you can do it,all that other stuff of grease and breakin oil or anything else is a waste of time.To rebuild a v8 I use nearly a quart of 10/40 oil to put it together with.
Nolan
03-28-2002 07:56:35
Do consider how you're going to turn that engine over once you get it together.
You can just crank it until it starts. That is a valid aproach. It's one I personally don't care for much, considering how long it takes to get oil up those empty passages to things like rockers and such.
I personally tend to remove the spark plugs and on overhead cam engines losen the valves to non-functional. I then crank it over until I (a) get oil pressure up, and (b) can visibly see the oil flow at the rockers. You'd be amazed at how long b can take.
Then I set valve lash, install the plugs, and and fire it up.
Tyler(WA)
03-27-2002 09:40:10
I use Lubraplate assembly lube. There are many good brands.
Here's the probelm. A new engine has no oil up in the galleys and it takes a while for the first oil to push out all the air. Those first many seconds are not only critical but really tough on fresh bearing surfaces that have not polished in yet.
Assembly lube is a creamy material that won't drip away. It clings to the surfaces until fresh oil washes it away. Between the heat and washing of the fresh engine oil, nothing reamins.
I'd never spend all that time building a new engine only to have a lot of wear occurr when I first turn the key. Assembly lube is worth the time.
Glenn(WV)
03-26-2002 20:16:52
I have always been told to use engine oil as an assembly lube, with the exception of the cam; cams often come with their own assembly lube. Having seen racing engines built, I can tell you that many such builders use engine oil. My $0.02.
Ray,IN
03-26-2002 20:48:38
 Re: Re: assembly oil in reply to Glenn(WV), 03-26-2002 20:16:52
I've always used 1/2 motor oil and 1/2 STP or motor honey, etc. mixture since I became interested in engines back in the late 1950's. I've not had a damaged bearing yet.--knock knock.
Vince
03-29-2002 19:40:02
 Re: Re: Re: assembly oil in reply to Ray,IN, 03-26-2002 20:48:38
I have removed the distributer and made a shaft that went to the oil pump and ran the pump with a drill to prime stuff before. I have heard of useing a pump up sprayer full of oil with a conection to an oil gaily. quicker to repace a pipe plug than to set all the valves.
Cubub
03-30-2002 07:02:06
 Re: Re: Re: Re: assembly oil in reply to Vince, 03-29-2002 19:40:02
To me thats the easy way Vince. What I do is use a clean plastic garden sprayer and a couple quarts of oil. All one needs is a hose barb to pipe adapter, pump it up and release pressure just before it runs out of oil, a plastic tank/sprayer allows you to see thwe oil level. I still like assembly lube on cam and 50/50 oil/thick stuff (Power Punch, STP, whatever) on everything, and a few drops of oil on cylinders/pistons.
