Hobart 135 wire feed welder 110/120 volt
Arn
03-25-2002 18:28:37
Need some help here looking at a Hobart wire feed welder 135 110 volt are they any good? would not be used that much but though it might be ok for some light hobby stuff etc. what extra would be good to get? any sugestions appreciated thanks
DumOleBob
03-27-2002 16:16:07
 Re: Hobart 135 wire feed welder 110/120 volt in reply to Arn, 03-25-2002 18:28:37
Got one & love it! Got rich so I'm getting a 250, but will keep my handy Hobart - plug it in anywhere! Use the Argon/CO2 gas.....Have a ball!
RobertTX
03-26-2002 06:01:39
I am very pleased with mine. I went back and forth between this one and the 220 volt one. I am glad I got this one because I can move it where I want it. I found that a major difference between this and a stick welder is that you can't just put a long lead on the MIG to go where you want. I had not considered this, so the 135 worked out great for me. I have used both the flux cored and solid wire, they both are good, but in different applications.
Mike W
03-25-2002 20:46:03
Hi Arn, I would suggest using gas and bare wire. I tried the flux core wire and plain old co2 is much better. I have a Hobart 200 amp machine, 15 years old and still going strong. I run at 100 amps with .035 wire. It draws 17 amps at 240 volts ac input.
A 120 volt machine would be nice for taking outside.
Check the duty cycle some are 20%, others are 60%. 60% means you can weld 6 min. out of 10 min. You may find yourself doing more welding then you first thought; I know I did. Regards, Mike
walt
03-25-2002 19:30:52
Got one bout yr ago. Very pleased. Make sure you have a 20amp outlet for it. Have you looked at the Hobart site? Take a look..
