Acetylene Torch Settings
Wayne Wiseman
03-25-2002 16:53:57
I have the large tanks of acetylene and oxygen with Harris torch outfit.
My settings are 7/40 but when I cut metal I don't get a clean cut. The melted metal accuumlates on the side of the cut which makes a ugly cut. Have to grind the metal off. Can someone help as I'm new at this trade. Sometimes the cut will close up with melted metal. Any books or website that can explain the settings would be helpful. I normally cut 3/8 and thinner metal. Thanks. Wayne
tyler
05-29-2004 17:20:54
 Re: Acetylene Torch Settings in reply to Wayne Wiseman, 03-25-2002 16:53:57
turn your oxy up to 70 psi.
Trucker
04-03-2002 22:14:07
Torch isnt set right or you are going too slow,or both.
bill b va
03-26-2002 01:08:36
are you fully depressing the oxy lever after preheating ? i have found some inexpeienced people don't depress the oxy lever all the way and there fore don't get the full amount of blow from the set oxy pressure . this will in turn will cause the problems described above .
JMS/MN
03-25-2002 20:52:54
Along with the advice of T bone, try 7 and 50 for your settings. The extra oxygen should help to blow the cuttings out of the way. For heating I run about a 3 to 1 ratio- 7 and 20+, but for cutting I usually run about 7 and 50. But nothing beats a clean tip.
T_Bone
03-25-2002 18:07:22
Hi Wayne,
click on the below topic as I just finished writing about cleaning a cutting tip. Your tip is very dirty and this will explain how to clean it.
T_Bone
