Parts washer fluid?
Roger V.
03-25-2002 15:54:50
What is the best fluid to use in a hobbiest-type (non heated or agitated) parts washer? I've been using fuel oil but can't stand the odor. I hear water-base is the least dangerous but doesn't work very well. Cost is somewhat of a factor. What's your experience? Roger V.
Roger V.
03-27-2002 14:15:18
 Re: Parts washer fluid? in reply to Roger V., 03-25-2002 15:54:50
Thanks for the info. BTW which has the most odor and flamability, kerosene or mineral spirits?
Rick from Paso
03-26-2002 22:28:35
Diesel works pretty well, not too flammable and cheap.
Denny Frisk
03-27-2002 10:53:53
 Re: Re: Parts washer fluid? in reply to Rick from Paso, 03-26-2002 22:28:35
RICK - I went with the Expensive stuff!!!! 5 gal. of Kerosene with a gallon can of GUNK degreaser added. Works good too!
Jerry A.
03-26-2002 14:57:05
I thought I'd be a good citizen and try one of the soy based solvents (Soy Gold). Virtually no odor and easy on the hands, but I have to admit, it really doesn't seem to cut the grease like good old mineral spirits. I'll probably get a bucket to keep outside (to cut down on the odor) and put mineral spirits in it for a "pre-soak" before finishing with the biodegradeable solvents. The low odor mineral spirits sounds appealing, but mighty expensive where I live.
JerePa
03-26-2002 17:33:42
 Re: Re: Parts washer fluid? in reply to Jerry A., 03-26-2002 14:57:05
I use REGULAR AGITENE #M2062. It works well but is expensive. $55/5gal. Has a flash of 105deg. low oder & easy on the hands. Comes down to how much you want to spend.
Butch in Ks
03-28-2002 19:42:38
 Re: Re: Re: Parts washer fluid? in reply to JerePa, 03-26-2002 17:33:42
I use solvent in parts washer get it from my Phillips 66 bulk agent, it is filtered through small filter never losses it strength but does get dirty depends on how much you use it scrape the bottom clean and back in busness again it will dry off of parts rhat have been washed amd the flash point is up about like diesel I use rubber glove just to be safe
speed bump
03-25-2002 21:52:26
Hi roger, Im throwing out 5 gallons of simple green , total waste of money and time . Im going with low oder mineral spirits this time.
