Static Phase Convertor on Grinder
Robert in Md.
03-25-2002 15:10:40
I purchased a 10 inch bench grinder Saturday at an auction . It has a l HP , 1750 RPM, 3 phase made by Snap-On. How would this grinder run an ENCO static phase conventor. I know it will have less power but is it going to be slow and Hum alot. Even though I don"t have 3 phase I couldn"t resist this big heavy grinder with about 20 extra grinding wheels for $30.00 Thanks, for any advise.
george md
03-26-2002 00:29:31
 Re: Static Phase Convertor on Grinder in reply to Robert in Md., 03-25-2002 15:10:40
Robert,
if you don't want to build one, a co in florida builds one that is good for anything up
to 7 1/2 hp and can be paralleled with more units
for more hp . i have 3 units in parallel to run
machine shop , lathes, mills,horizontal boring
mill, bridge cranes, large horiz press. have been using that set up for 25 years, it works.
one lathe has 7 1/2 hp, one has 5 hp,little
one is 1 hp, boring mill is 7 1/2 hp,cylindrical
grinder has 5 hp + all the little motors on it
spindle, hyd pump, coolant pump.
the company is --reliance research &
manufacturing co Phone # 407-862-3038
1024 Ashworth Cove, Altamonte Springs,
florida 32714
any questions , email me, i'm in md
VaTom
03-25-2002 19:14:30
My experience with static convertors is that the old motors did allright but that newer motors ran very hot. Do yourself a favor and run a search here for info on how to build a rotary phase convertor. $25 should be the most it'll cost you and it's incredibly simple to do. I use a 5hp dummy motor and never bothered with anything to get it started other than a chain gear on the shaft so I had traction when giving it a kick.
If you've seen "slow and Hum alot" you've seen a motor using too much current and getting hot, not unusual for static convertors. Make your own best guess about life span. I've been running a rotary for 20 years. No problem, and cheap.
Johnny in NE TX
03-25-2002 15:52:21
Yes it will run on a phase converter, There is some new electronic technology converters that will allow you to obtain your full 1 hp. but may also cost an arm and a leg, do a search on "3 phase converters"
