Stud Finders
Tim B
03-25-2002 09:47:17
I am thinking about buying an electronic stud finder. I've never used one. Any opinions as to whether they work well, recommendations as to type or brand?
Nolan
03-27-2002 04:21:26
 Re: Stud Finders in reply to Tim B, 03-25-2002 09:47:17
Insulation can thoroughly defeat them. I had my house insulated with blown in foam. Now, the stud finder cannot find anything. Wasn't a problem I anticipated.
Roger V.
03-26-2002 13:13:18
I have the basic and the supposedly better 5.5 and neither have been consistent, but better than nothing.
big fred
03-25-2002 12:46:24
I've used mine on 1/2 inch and 5/8 inch drywall and doubled 5/8 inch at work, with good results. I've also used it thru 5/8 inch with 5/16 T&G wainscoting and thru 1/2 plywood with good results. It's one of those basic "homeowner" versions, think it cost about 12 bucks at Home Depot when I got it 10 years ago.
RayP(MI)
03-25-2002 11:23:24
I have one that Radio Shack used to stock - works fairly well. Usually also check my findings with a magnetic stud finder, and try to locate nails in the wall too.
BB
03-25-2002 10:03:10
I bought the cheapest one that Home Depot sells. I forgot what it cost but less than $20. It works quite well on standard drywall. More expensive ones are supposed to have deeper penetration.
pete
03-25-2002 12:06:32
 Re: Re: Stud Finders in reply to BB, 03-25-2002 10:03:10
My experience has been that they are unreliable on insulated walls when there is foil backing. I had better luck finding one stud and measuring from there. That assumes a wall built to code,of course. The finder works well if the insulation is faced with Kraft paper.
Johnny in NE Tx
03-25-2002 15:55:33
 Re: Re: Re: Stud Finders in reply to pete, 03-25-2002 12:06:32
I agree with Pete on this one, I install cabinets for a living, don't spend more that 15 bucks on one and keep a fresh battery in it.
