Stuck carb throttle shaft
Mike W.
03-23-2002 19:48:58
Greetings, great info here. I have a carb with a stuck throttle shaft. I got the throttle plate screws out by using a little heat on the screws.
Nothing is holding the shaft except for the frozen shaft to bore fit. I have been using PB Blaster spray for a week now along with heat from a hot air gun.
Also tried gentle taps on both ends of the shaft. Anyone have any other ideas? Thanks, Mike.
Tom
03-24-2002 16:51:33
 Re: Stuck carb throttle shaft in reply to Mike W., 03-23-2002 19:48:58
How about heating the carb and shaft to 200-300 degrees, putting a cardboard tube down the bore to insulate, then putting ice cubes down to cool and shrink the shaft. Might work.
Don Young
03-23-2002 21:37:23
In a case like that the best advice I can give is to be sacrifice the cheapest, most available part. If you cut the shaft in two, you may find that one end is not badly stuck or both ends may loosen easier. Turning both the inside and outside ends of each piece may work. Finally, carefully cut or grind each piece off close on the outside and verrrry! carefully drill out with a slightly undersize drill just deep enough to be thru the body, leaving a thin shell. Use a small punch in the bottom of the hole to tap the thin shell and rod out. If you don't feel comfortable doing this, a good machinist can do it for you. Hope this helps.
