Hot water high pressure washers
bigbadjohn88
03-20-2002 15:55:22
Does any one have experience with high pressure hot water washers. I am looking at Aqua Blast or Diamond. Also has anyone used one with the steam option. I don't know if that is need or not. Thanks for the help
boog
03-20-2002 22:26:38
 Re: hot water high pressure washers in reply to bigbadjohn88, 03-20-2002 15:55:22
I have a Landau hot water washer which I like very much. Hot water will take grease and crud off much better and does not leave a film like cold water does. We often just wash with hot water only, no soap.
I would recomend one that has 2500 - 3000 psi and puts out at least 3 gal/min. Also one that heats to about 200*. Caution, water over 145* will remove wax.
You also will need aan assortment of tips, 0*.15*.25*, and 40*. Each has their place. I also recomend a Rotomax or similar(spining 0*) nozzle. They are great for removing large buildups of grease and dirt, and will remove loose paint.
Be sure to get one that has downstream injection. That way the abrassives in soap will not go through your pump. Most times we spray soap on with a hand sprayer and let it soak before rinsing.
Hope this helps
boog
