Hydraulic cylinder repair on 4 ton floor jack
Idahoboy
03-19-2002 15:01:40
Has anyone replaced o-rings and seals on a floor jack hydraulic cylinder? Anything special about doing this job? Thanks in advance.
ShepFL
03-21-2002 06:54:05
 Re: Hydraulic cylinder repair on 4 ton floor jack in reply to Idahoboy, 03-19-2002 15:01:40
What part of Idaho are you from? I am originally from Bonner/Boundary county area (Panhandle). Now living in N FL.
Gary Sanders
03-21-2002 08:31:37
 Re: Re: Hydraulic cylinder repair on 4 ton floor jack in reply to ShepFL, 03-21-2002 06:54:05
I have a related question maybe some of you can comment on. I won't have any problem with stopping a leak at the pump, but mine doesn't leak externally. If you pump the handle, the saddle raises fine and then immediately goes back down. In talking to the local repair shop about costs, the service manager mentioned that for a flat fee they hone and reseal the pump and "reseat" the check valves. This is the grey area for me. It appears that this might be my problem of a check valve not holding. If I understand the jack properly, there are two checks in the system along with the pump. Can anybody elaborate on this "seating" of the valves.
jerry Gerthofer
03-19-2002 18:01:08
no its simple.. saveing your self a pile of bucks.is all go for it..... .
zira
03-19-2002 16:18:40
Depends. What brand of jack is it? Many of teh cheaper Chinese hydraulic jacks are welded shut. You also cannot get parts for them. Older, American made jacks (Lincoln, Walker, Hein-Werner. Ausco, etc.) are pretty straight forward. You can get a parts list & exploded diagram faxed to you for Lincoln, Walker, H-W, & associated jacks, e-mail me if you want their number.
Better "name brand" imported jacks aren't too hard to get partd for, such as Jet, Norco, Lincoln Guardian. Sears tends to sell assembleys rather than parts for theirs.
If you need the names of some suppliers for American-jacks, e-mail me.
David
Ed Johnson
03-27-2006 07:15:48
 Re: Re: Hydraulic cylinder repair on 4 ton floor j in reply to zira, 03-19-2002 16:18:40
I have 2 old walker 4 ton jacks. I put kits in both. They came with the jacks at an auction.
I still have a problem with the jacks by passing
under a load. They bypass at 200 lbs. There was no assembly info or breakdown. I am in need of info. to see if I did something wrong or if
I can adjust something. Thanks
steve vietro
07-03-2006 05:32:31
 Re: Re: Hydraulic cylinder repair on 4 ton floor j in reply to Ed Johnson, 03-27-2006 07:15:48
I have a Hein - Werner 12 ton hydraulic jack Model 912. Do you know where I can get parts and a breakdown for this sick puppy.
Loridk
07-20-2006 14:02:32
 Re: Re: Hydraulic cylinder repair on 4 ton floor j in reply to steve vietro, 07-03-2006 05:32:31
Hydraulic jack 800 548-0090
Blackhawk parts 423 622-9898
mike tromp
03-22-2006 18:13:01
I have a 3 ton jack made by blue point. looking for a exploded diagram to r/r jack o-rings. I have a new seal kit for it already. Thanks
bungy42
02-10-2006 07:20:18
I doubt this thread is still alive after all this time, but if someone could send me a source for Walker jack parts I'd appreciate it.
Loridk
07-20-2006 13:59:02
 Re: Re: Hydraulic cylinder repair on 4 ton floor j in reply to bungy42, 02-10-2006 07:20:18
Bud worthe
07-12-2004 10:46:57
need parts for a old walker lift a car floor jack, tag smashed, but I can make out NO 8 series B 3000 lb. racing wis, may be a 828 like I saw someone else looking for, thanks for help, parts I need are the piston , washer assembly, the shut off swivel plug that works from the handle, bud
Steven Nahulak
11-05-2003 09:50:08
I need to order a kit to rebuild a Lincoln 4-ton hydraulic cylinder. Can you give a number to call to order? Thanks
joe
01-05-2004 17:04:21
 Re: Re: Re: Hydraulic cylinder repair on 4 ton flo in reply to Steven Nahulak, 11-05-2003 09:50:08
hi can you email me the names and numbers for the suppliers for the american jacks
thanks,joe
