Choosing a Welder
Jeff
03-17-2002 13:45:38
I am in the market for a new stick/arc welder. I have already decided I want a 220v machine that puts out 200-250 amps of power.
I only need to weld steel, and maybe cast iron. Most welds would be flat or on the side, no overhead. Would an AC unit work fine for me? I really don't want to spend money on DC current if I don't need it.
What brand should I buy. I have looked at the Lincoln 225AC and I noticed it doesn't have infinite control, just certain settings. Anyone have opinions on the Hobart235AC? What about Century? Do they make good welders?
What model would you recomend?
Thank you
Jeff
John from Ky
03-19-2002 19:08:25
 Re: Choosing a Welder in reply to Jeff, 03-17-2002 13:45:38
Lincoln does make the best 220 volt welder. Although it doesn't have the variable amp adjustment, it is a better unit than the Miller or Hobart (which is also a Miller!) Also, the others are right, spend the extra and get the AC/DC welder. It will do a lot more once you learn how to use it.
BFO
03-18-2002 03:28:23
Do a web search on these models;
Miller Dialarc 250
Lincoln Idealarc 250
Thermal Arc TR250
HTH
Greg
03-17-2002 20:25:21
Hi Jeff
My quick 2 cents. Would be to wait and save even if you have to for the AC/DC machine. As you learn more on welding of different type of metals and the different electrodes available. You may one day kick yourself by going with a AC only welder and the narrower selection of electrodes for it.
Once I switched over to the DC side of the welder, I'ld be willing to bet that I would'nt even have to take my shoes off to count the number of times my welder has been on AC in the last thirty years or so.
Butch in Ks
03-17-2002 17:22:12
I dont know why you want one with such hig amps had a 295 wards never had it over 150 i think the best a c i had was an p & h vairable also you can buy 7018 for a c welder i now have 225 miller a c d c it woill do any thing i need to do
