PITMAN ARM REMOVAL ON FORD 8N
JIM
03-09-2002 08:17:19
DOES ANYBODY KNOW ANY SECRET TO REMOVING PITMAN ARM ON FORD 8N? I CAN'T GET PULLER TO HOLD. TRIED HEAT WITH PULLER. CAN I USE BALL JOINT FORK? ANY TOOLS OR SUGGESTIONS? THANKS A LOT. JIM
Pickle Fork...Mikey
03-10-2002 19:23:59
 Re: PITMAN ARM REMOVAL ON FORD 8N in reply to JIM, 03-09-2002 08:17:19
My '41 9N was solid, but I lubed it with PB Blaster and let it sit overnight.
$3.00 Pickle fork from harbour freight and two good smacks. Each came right off.
Leave the nuts on, but loose! the amount of force holding those buggers could cause some real damage if you aren't carefull.
Mikey
bbott
03-09-2002 11:00:58
I've never done an 8N, but have conducted some epic battles with pitman arms on other vehicles. It's amazing how they can hold on.
In the past I've had to make my own custom-fit pullers out 2 pcs of bar stock, all-thread and a heavy jackscrew. There can be lots of time involved in doing this, but sometimes it's the only way.
Only other advice I have is be patient.
Heat that arm up.. use a good quality penetrant like Kroil or PB blaster and let the heat draw it in until cold. Repeat..repeat.. etc. May take awhile. (days) Hopefully you're not in a hurry.
Maybe somebody else will have some specific advice for an 8N like 'remove the hidden bolt'..
-- bbott
