Carbon arc torch
Ken2n
03-07-2002 09:40:50
Does anyone have any info on the lincoln carbon arc torch (k1876-1) What it will do and is it worth fooling with
thanks for any input you might have Ken2n
Fred OH
03-08-2002 10:18:09
 Re: carbon arc torch in reply to Ken2n, 03-07-2002 09:40:50
It's okay to have a carbon arc torch laying around cause you never can tell when the oxygen bottle will run out and the time isn't right to get another bottle and all you needed was a little more heat. It's pretty cheap to operate but is kinda rough on finished surfaces especially if you hold it too close. You can even braze or solder with one too. If you would hide your accetylene torch, you might find out a lot of things that could be accomplished with one. L8R.....Fred OH
Dave F.
03-08-2002 09:41:33
I would'nt pay alot of money for one I got my at a flea mkt.for $5.00 the carbons would probably cost that much. its, just another boy toy for me I played with it some heated & bent some metal it sure will light up the place if its dark, not very cost effective, oxy/act. is the best way to go. my .02 worth Dave F.
Rod (NH)
03-07-2002 11:29:47
Hi Ken,
I have one of those from many years ago...got it along with a little 225amp AC "buzz box" welder. I haven't used it in a VERY long time. If you do not have a oxy-fuel gas torch, it would be good to heat up rusted bolts and nuts for easy removal. I think that's all I used to use it for anyway. The "flame" temperature is said to exceed that of oxy-acet so it is hot, indeed. I found it rather cumbersome to use and not very useful in tight areas. But if it's all you got, it can be helpful on a limited basis. I have a 3-page description of "how to" and stated uses for it. I would be glad to scan that and email it to you if you wish. Rod
Ken2n
03-07-2002 17:35:15
 Re: Re: carbon arc torch in reply to Rod (NH), 03-07-2002 11:29:47
Thanks for your input Rod I don't think I need the description. I am going to look into a oxy-acet. outfit. Ken2n
kraig WY
03-08-2002 08:16:52
 Re: Re: Re: carbon arc torch in reply to Ken2n, 03-07-2002 17:35:15
Good Choice. Had one of those carbon arc torches, used it a couple times and threw it away and bought torches. Don't miss it at all. Wasn't gonna say anything cause didn't want to hurt any feelings.
Rod (NH)
03-07-2002 19:24:09
I think you are definitely making the right decision. Best to put the money into an oxy-acet or oxy-propane outfit (see prior discussion a while back).
Rod
