Welder was great in it's day. I'd stay clear of it to be completely honest with you. Depends a lot on the area you are in too. Here, parts for these old work horses are hard to come by and if you do find 'em, you'll pay a premium price. Aside from the DC aux power limits, output is only CC with a low response curve. Great machine for playing around doing DIY'er stick work but far gone from the production scene. Unless you check parts availability and cost and can get them little of nothing, I'd suggest saving your money and getting a newer machine or a new machine. Just think, say you give $400 for this one. It them costs you say $200 for a mag to get it spark and $75 for a gas tank to get it fuel. You then find that the auto-idle does not work, there's another 250 bucks. You get these fixed and carb starts leaking, another sum of money... See my point. Old machines like this are nice to keep you busy if you got nothing else to do. If you're looking to get some welding work done and not working on a welder, you're better off putting your time and money into a new machine. Deals on used engine drives like the older style Miller Bobcat's and Trailblazer's are to be had quite readily. Base machine new will run you around $2200 or with some options $2800. Used ones with say 500-1000 hours on them can be had for $1200 or less. Just got an 80's model Bobcat last november for $850 with 902 hours on it. Changed the oil, filters and put some good gas in it and repaired the choke cable in 2 hours at a total cost of 38 bucks including the gas. Machine now has 1195 hours on it and is perfect. Just a little advise to think about.
