Shop vaccumes
Scott Green
03-06-2002 22:19:28
I'm looking to buy a good shop vaccume. What better place to ask for advice / opinions. Looking for pros and cons of different brand names. Also looking for features / attachments which I should have. Thanks for your time. Scott Green
Scott Green
03-07-2002 21:53:28
 Re: Shop vaccumes in reply to Scott Green, 03-06-2002 22:19:28
I thank you all for your input. Lots to keep in mind.
T_Bone
03-07-2002 16:22:52
Hi Scott,
I just bought a Rigid 6gal small one for $40 at Home Depot. It really supprised me for a cheap one that it would work so well. I bought it for outside use and good thing I did as it does blow dust back into a inclosed room more than it should. For cleaning out the truck and such it'll work ok. For my shop I'd want something better.
T_Bone
Greaseman
03-07-2002 09:23:50
I have Craftsman that has been used for my floor and rug cleaning business (this pay's for my trac-tor stuff). I like it except that it is noisy. I will recomend you checking other brands as these each have both good and bad on each. One thing I recomend is not having wheels that stick out from beneeth the barrel. If you put any preesure on it they break right off, then it is harder to move around! Another thing, if you are picking up large volumes of fluids ( like I do) get one with a squeege assemble. I am looking into one when either the shop vac motor burns out ( which is probably soon!) or the tank rots out, I am going to invest $400 into a new machine with a stainless steal tank. If you have a plastic motor housing, you can put a self tapping screw into to hold the hose so it doesn't pop out all the time.
ShepFL
03-07-2002 08:34:41
I plan to do the same as John except with a formal built-in vac system. Approx. $600 if I do installation for my new house construction. Shop should be much less, as less square footage and also buying units at discounted price since buying 2 not one.
This way it is DONE once and for all. Also for small workbench cleanup and tractor mods I use a pnuematic hand vac. I got it while working as aircraft mechanic -compliments of Lockheed Aerospace. Sucks up drill shavings, bolts, nuts, string tie, etc. without a thought. With these I can keep shop clean and safe.
John
03-07-2002 08:16:56
I went the next step in vacuum units. I took my old shop vac, Put it on a 30 gallon drum, piped it all over the shop using PVC, with simple caps as shutoffs. Exhausted it out the wall. And this is wonderful I can vacuum my car, collect sawdust, and even get rid of grass clippings on my lawn tractor. It is wonderful
Glenn(WV)
03-07-2002 05:27:19
I have a six-horsepower 16-gallon Shop Vac. It is quieter than my upright household vacuum. I'm really pleased with it.
I bought Dad a five-horsepower 16-gallon Craftsman several years ago; he's really pleased with it. The only gripes he's had with it is that the hose is splitting apart and that there is no way to lock the hose on the vacuum itself(it keeps wiggling itself loose during use).
JerryU
03-07-2002 04:44:22
I bought a Craftsman-big and powerful. Suck the paint off the walls if you don't watch out, but---noisey as all get out. Couldn't stand being in the same room. Finally found out they make a muffler for it. $12. Works pretty well. Moral: you may want to listen to it before you buy it.
JU
Ben
03-07-2002 03:08:56
Made in Germany, WAP
Best vacs ever. Real quiet & powerful.
Yours truly,
Ben
Farmer/Paul
03-07-2002 04:41:03
 Re: Re: Shop vaccumes in reply to Ben, 03-07-2002 03:08:56
I have had a number of the Shop Vac brand, and did not like them because they blow dust every where.. Bought a Rigid shop Vac from Home Depot. It has a cartridge type filter, easy to clean and if you use the extra fine filter for it they will Gurantee it forever. 2 years os steady work in the shop, cleaning my stoves, and sucking grain from my grain drill and no problems...
Mark Kw
03-07-2002 08:32:20
 Re: Re: Re: Shop vaccumes in reply to Farmer/Paul, 03-07-2002 04:41:03
I got one of the older style (black) Craftsman ones on a close-out sale. Don't like the design of the new tanks (red ones) but the vac itself is nice.
These also use the cartridge filter and work great. I did install a larger metal blast shield betweent the incoming line and the filter to keep the debris from damaging the filter. They come with a small one but it is just not quite enough if you are picking up a lot of abrasive material. All I did was take a piece of 16 ga sheet steel about 10" square, bend it in a V shape and bolted it to the existing plastic deflector.
Had the same dirt blowing problem with the Shop-Vac one that Farmer Paul did. Got rid of that one in a hurry.
Farmer / Paul
03-08-2002 03:59:51
 Re: Re: Re: Re: Shop vaccumes in reply to Mark Kw, 03-07-2002 08:32:20
Thanks for the tip on the dust shield Mark , I'll be making one this morning..
Neil
03-08-2002 08:11:20
 Re: Re: Re: Re: Re: Shop vaccumes in reply to Farmer / Paul, 03-08-2002 03:59:51
I have a very old Craftsman that used to have a bag type filter. When I went to get a new filter I found they had a kit to convert it to a modern paper cartridge type filter.
When the 25+ year old plastic barrel cracked, I put the motor onto a 32 Gal metal trash can.
Then it sucked the sides of the can in, so I made some suport rings out of conduit.
For a sheild for the filter I cut a hole in the botom of a 5 gal paint can, and put it under the filter, with the open end facing down.
Of course for a lot less I could just buy a new. one
